Replacing Salus RXRT505 with Drayton RF601
3 Mar 2022
The wireless transmitter has packed in so the Salus is coming out and being replaced with the Drayton.
The Salus has Live and Neural connected to the boiler along with the Grey from Normally Open to Lr on the boiler. Live has a jumper to Common on the Salus receiver.
The bit of toilet paper supplied with the Drayton is poor so had a look at the site and it looks like I need to put the jumper wire between Live and pin 1 and my grey wire to pin 3.
Can someone please confirm i have this right.
Thanks.
If your Drayton is the same as above, then you're right. It's the same principle. Add a link between 'L' and 1 'Common'. Then Live Return [Lr] goes to Drayton 3 'Call for Heat'
