Replacing Seals in a UPVC window
5 Nov 2009
Hi All
I have managed to locate some suitably sized replacement rubber seals for some of my windows. Does anyone have any tips of how to replace the seals, or is it just a case of removing the old seal, and then replacing with the new seal?
Will i have to use some sort of adhesive to fix the new seals in place?
Alex
All depends on the type of rubber seal you have really.
Wedge gasket just pushes in, firtree gasket locates into a groove but you'll need to remove the glass to put this in and then theres security tape, same as firtree, you need to take the glass out.
Or if none of them can you post up a photo on here showing the cross section of the gasket and i can tell you for sure
