Hi Folks,
I've got what is essentially a shed attached to the side of my semi, it's got a decaying flat felt (part torch on, part patched) roof and it needs replacing, but I'm also planning on making better use of the space so want to give it some insulation.
The building is 2.3 meters high, so my plan was to go with a warm roof using framed 100mm kingspan/celotex PIR, ply on top and then EPDM. This would take the total height up to around 2.4M.
Am I right in thinking this is permitted development given its both an essential replacement (the current roof leaks), and still under the 2.5 meter limit for a shed. I wasn't too sure if the fact its attached to the side of the house makes a difference or not.
Cheers
Cheers
