Replacing Shower Cubicle
8 Dec 2010
Hello
I currently have a curved shower cubicle which is nearing the end of it's life. I haven't found the design of the shower to brilliant - for example, when we had problems with the waste we would have to rip up the cushioned lino and ply board then remove floor boards to get at the waste.
I don't want to make this mistake again - what is a practicle solution please?
Many thanks
George
The key is good waste run design and a quality trap, fitted well.
Then really only 1 way to do it, have a professional design & fit the waste run and install the cubicle, that then should be leak free and then good use habits to keep it blockage free.
The only alternative I can see is to raise the shower on a riser kit/platform leaving an accessible front panel, compression fit the trap and then solvent the rest.
This doesn't mean a lot to me. Are there any links to pictures etc?
I've seen images of raised shower trays with plinths attached to the legs but I think they look a bit unattractive. I do like the look where the shower is mounted directly on the floor (as it is now).
then your back to what madrab has said either looks or practicality
Yep, well planned waste run too, proper fall and the straightest route, solvent weld, should give years of problem free drainage. Clean it regularly.
How can I clean it regularly if it is hidden under the floorboards - or do you mean I clean it from the top where the water exits from the shower?
When traps leak, I find it easier to resolve issue from below (if access is possible) rather than messing around with floors - ceilings are easier to make good.
Unless it's in the Sistene Chapel :eek:
Or would that be Cistern Chapel :D
How did the Pope get your number, dilalio?
