I have a Mira Fino shower (the "exposed controls" version), and need to change the flow valve as it is getting harder to turn off the shower completely.
I have acquired the relevant spare parts - new flow valve and new on/off lever, including all relevant washers.
The instructions warn me only to use a silicone-based lubricant when assembling, but they don't mention where it should go. There's a very small, sealed polythene packet in the box about the size of an AAA battery containing what I assume is the relevant lubricant. Should it be applied:
(1) around the threads of the screw joints
(2) where the on/off lever connects to the flow valve
(3) around the washers
(4) somewhere else...?
Also, any general tips on replacing shower flow valves appreciated - I'm a complete novice when it comes to plumbing.
Thanks,
Dave
Thanks,
Dave
