- Joined
- 1 Oct 2023
- Messages
- 5
- Reaction score
- 0
- Country
Morning all,
I am replacing a sink in a small downstairs bathroom with a new vanity style basin.
The existing pipework is 10mm microbore plastic pipes with a push fit connected to an isolating valve connected to a 10mm copper pipe which was connected to the old taps (see images: example1 / example2).
The new taps come with 22mm flexible tails (see image), I understand that I need a 22m isolation valve and a reducer to fit that valve directly to the 10mm microbore plastic pipes. We had the same setup in an upstairs bathroom which was totally revamped and it appears this is the same approach that the plumber took for those (see images: example1 / example2)
Does the above approach sound sensible or would you tackle it differently?
I am struggling to find a 22m>10mm reducer. Should I instead purchase a 22mm>15mm reducing coupler and a 15mm>10mm reducing internal coupler?
What is the best way to connect the new isolation valve to the existing plastic microbore pipe? Do I need to use the push fit or can I just remove that and put the pipe directly into the valve as the plumber appears to have done upstairs.
Many thanks in advance
Andy
Andy
