I’m after a bit of advice on the easiest way to replace a basin trap. The trap is one of the flexible corrugated things and must be filling up with gunk as I struggle to get rid of the smell coming from it.
It connects to the 32mm waste pipe using a solvent weld coupler. The waste pipe then runs straight out of the wall to the hopper outside. There’s not enough room to cut the pipe after the coupler to connect a compression fitting.
Is there a way around this without having to run a new length of waste pipe back into the house - it’s quite high up as there are two floors below and i’ll probably struggle to reach from my ladders.
Cheers
Cheers
