Plumbing and I don't always see eye to eye, so I thought I'd post what I was thinking of doing, and see what the experts think.
Our dishwasher literally fell to pieces. Well, it had it coming. Just buy a new one, and connect it in place of the old one, right? Except that the stop-tap doesn't actually turn off the water.
(Yes, I do know it's in the 'on' position in the photo - makes no odds what position it's in, really.) What can I say? It was cheap. I should replace it with something better - any recommendations? It's connected directly to the main supply, and we're in a hard water area, if that matters.
That brings me on to my second problem. The main internal stop-cock doesn't work either. And no, it isn't just because the handle fell off.
It's very stiff, but I can still turn it with a Mole wrench on the spindle - however, even when it's reached the limit of its travel, the water still gushes out. Plainly I should replace that, too... Assuming I can find the external stop-cock, that is. The hole under the little flap out on the pavement seems to have nothing but mud down it. There must be a tap down there somewhere, surely, but perhaps I should invite the water board to sort that out. They wouldn't be pleased if I broke something.
Anyway, any recommendations regarding the internal stop-cock? It has 22mm plastic pipe coming in, and 15mm copper coming out. I'm assuming I can just buy something similar and connect it in. I don't seem to have a drain cock anywhere - do I need one of those, or are the nearby kitchen taps good enough to drain the system?
Thanks for reading, if you made it this far. And thanks in advance for any advice you can give.
