I'm about to change the sump gasket on a peugeot 206 (1.4, 2001). It looks easy enough but I'm woundering about the front exhaust pipe + cat. It hangs just under the sump but is not obstructing any of the bolts, I think I should be alright to leave this on, undo the bolts and then drop and slide the sump away.
However, if I need to drop the exhaust do I need to replace the gasket between the exhaust and manifold?
Many thanks
Peter
Many thanks
Peter
