Hey guys, I recently done a broadband speed test in my mothers house and to my shock the download speed was 0.7 (with Sky claiming up to 24, average of 7-8). Anyway, there seems to be a large excess of old wire (around 10-15m) just coiled up behind the cupboards so I've decided to replace it all, move the master socket into the living room and plug the phone & modem directly into it.
The above pic is where the outside wire (right) is attached to this box, is it worth replacing this box? What type of box is it? If I've done my research correctly I want to replace the wire on the left (CW1308?) and run it into the living room to a master socket (NTE5?) and then use a micro filter for both broadband/phone connections.
Also there are green and black wires coming from the right wire (see picture) and which go into another wire not even connected to anything, can I cut it off? Do I need to turn anything off to do this work?
Could anyone please shed some light on this? Should I keep the original box in the picture and just run the new wire to the new mastersocket or replace that box too? Do I use copy the two blue wires in the picture? How would I wire a NTE5? Thanks in advance!
