- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
I bought a Titan detail sander from Screwfix many moons ago and have used it only several times, in fact, it's only very recently that I've had to source new sanding sheets as I've now used the ones that came with the tool. Unfortunately, I couldn't find any that matched the holes but did find some that were close enough from Toolstation.
My problem is that after one or two sheets, the sheets no longer stick to the pad but fly off instead. Do you think it's because the pad needs replacing or dust is getting in between the paper and the pad because there's a couple of holes that either only slightly match up or not at all?
I've read that you have to eventually replace the pad but mine hasn't been used enough to be worn out. This model is no longer available and I'm not sure if can even get a replacement.
Is there a generally accepted hack of replacing pads on these tools when the specific one is not available?
