Here's the scenario folks -
The bread knife has persuaded me to replace the two single bulb ceiling lights with two, three bulb ones. She has also requested replacement of the double switch with a double dimmer!
So far I have replaced the switch with the dimmer and managed to get one of the lights to come on and off and dim correctly, however, the other one either remains on permenantly (suggesting I've by-passed the switch, I think) or doesn't work at all.
It's a newish house and the builders weren't fussy about the core of cable they used for the wiring. In the light that won't work I have two cables coming from the ceiling - 1 a 3 core and 1 a 4 core. The 3 core has, earth, black and red and the 4 core has earth, blue, red and yellow. I am assuming the yellow is the switch feed as there is also a yellow one in the switch. I've tried all sorts of combinations but thought that this one would have worked - both reds (one from each cable, into the block and out through the 3 brown of the light fitting, back through the 3 blues of the fitting and out through the yellow to the switch. The blue from the 4 core and black from the 3 are isolated into a separate block.
The switch has the yellow into L1, 2 reds in Com, a red from the second light in the other L1 and another red in Com, with a small bit of wire joining the two Com's. The switch also has the blck from the working light, another black and a blue into a block isolated in the switch.
As I say nothing happens in the main light but the other comes on and dims ok.
Any ideas before I rip the lights down and shove them where the sun don't shine!!
cheers
Pricey
cheers
Pricey
