Replacing vinyl windows in a brick house
31 May 2003
Please tell me how I should mesure for new vinyl windows in my brick rancher home. I currently have aluminum windows and wish to install a vinyl replacement window in their place. How do I secure windows to the old rough opening?? Do attach them to the brick vaneer or to the wood in my walls???[/b]
assuming that you will be replacing the window + frame, you'll have to remove the architrave. From there you should be able to see how the window frame is secured. If you need to get the measurements, just run a tape and get the external frame size.
When you've got your replacement windows (inc frame) remove the old frame and install the new one...making sure it is level.
This site will give a bit more info:-
//www.diynot.com/pages/wd/wd005.php
