A simple question (I hope), but I am replacing some uplighters on the wall with brass wall lights. I have removed the first uplighter, and need to connect the wiring, but the width and size of the gap behind the new brass wall lights is too narrow and shallow to enclose a normal plastic connector.
How would you recommend I connect the wiring to enable me to enclose it behind the wall light? Are there "special" connectors I can use which can safely connect the wires so I can then insulate them with tape and/or a sheath? Any advise would be most welcome!
Regards, Sam.
Regards, Sam.
