I am replacing a wall mounted, shower mixer tap unit. When i took the old unit off, it fitted snugly into the connecting pipes and required a sharp tug to remove after undoing the holding nuts.
I have bought a new unit which stated that i needed pipes spaced at 150mm from the centres, which they are. However after fixing the new connection pipes there is a gap of about 20mm so the mixer unit cannot fit in tightly like before. This is i belive the reason why when i tighten the holding nuts the unit leaks very badly.
Any advise on what i can do? (other than perhas buy a new unit
