Hey.
I've got a 1930's semi. The outdoor stop-tap is approx 1m from the back wall with approx 3m run of pipe to get to the indoor stop tap. The first meter of pipe inside, after the indoor stop tap, is lead. The indoor tap is seized and the outdoor tap only closes the water to a dead slow trickle.
I was looking at having the feed from the mains to the indoor tap replaced with plastic piping (as well as both taps) so that I could re-plumb with pushfit.
Anyone got any idea of what this job would entail? Would it be a case of threading the pipe through the old pipe's channel or more a case of digging a fecking great hole around the pipe and routing under the foundations? Would I be best asking a plumber to do the work or going after a builder?
Not going to ask how much it would be here, as I know it's rather pointless!
Cheers much.
Cheers much.
