I have an old wooden casement window: there is an opening section 1200h x 500w (mm) and alongside a fixed window 950h x 500w (and a small opening section above the fixed part). The fixed part is cracked.
The window is on the 4th floor, so access is only available from the inside - is there any difficultly/problems with performing this work from the inside? Obviously the opening section allows 'reasonable' access to apply the putty, paint externally etc.
