the 1930s semi house has timber lintels across the internal skin but vertical header bricks on the external. the current windows have a timber frame but steel framing the panes.
If I replace these with upvc, how can I support the header bricks? I can pin them with props but i am guessing i need some kind of steel in place before installing the window.
Because there is no cavity Iam not sure what to use or what the best method is. Can someone help please?
