Hello,
I am looking to replace the two top wooden panels in a reclaimed victorian 4 panel door with glass to let more light into my hall.
I have reomved the two top wooden panels (which was detailed on a previous post) and carefully remove and retained the orignial beading from one side to leave two 100cm by 26 cm openings which is approx 1.6cm deep and has a recess all round where the wooden panel used to be recessed into the frame.
I was wondering what is the best way fix the galss in? I will be able to fix it to some extent when i reattach the beading but will need to fill the recess (because the largest glass i will be able to get in will be the size of the opening not including the recess). Should i just fill this with some kind of putty or sealant? Also do i need to get glass that is 1.6cm thick (the thickness of the wooden panel) or will i be ok with thinner glass and use putty/sealant/filler fill the gap between the galss and beading?
Any help is greatfully recieved.
Thanks.
Thanks.
