Hi there,
I intended on replacing my back door with a UPVC one I have acquired. The house is circa 1890 build with no cavity and from the outside a stone lintle is present.
On starting to remove the door frame (which sits level with the inner skin of brickwork) it has become apparent that there is no lintle on the inner skin, the top of the door frame extends either side into the brickwork presumably to hold up the brickwork.
To fit the new door this wooden "lintle" needs removing but I'm assuming upvc isn't suitable for supporting brickwork.
How would I approach this? I had thought of moving the top part of the door frame up one course of bricks and leaving it in situ to support the wall.
There is 4 courses of bricks before the course that is 'end on' above the frame. I assume that these end-on bricks that bridge both skins will offer some support to the wall...
Any advice gratefully received as I have a large hole in my wall now where a door should be and no uprights for the door frame so I'm kinda past the point of no return.
