Hi folks,
the zinc sheet on my front door flat canopy has cracked around one side and fallen off. The underlying timbers are exposed to the elements and there's some brown staining visible on the underside of the canopy.
I've asked a few guys to take a look but none of them turned up.
I'm just wondering if I can tackle this myself. Is this a DIY job ?
If so I'm unsure about how to deal with zinc sheet (and I don't want to use roofing felt)
Firstly, the local roofing supplier said they can sell a 8ft x 3ft sheet that's rolled up from the manufacturer, so to allow me to get it into the car boot (they don't do delivery).
How would I unroll it and straighten it out properly ?
The existing zinc goes straight into a pebble dashed wall - there's no lead flashing. So do I need to chop out a small channel of pebble dashing to before I can pull the old one out ?
How do cut zinc sheet ?
What do you do with the zinc at the corners of the canopy; after folder the zinc down to cover the timbers, they'll be a triangular overlap. Should I cut some excess out and tuck in underneath ?
Should I tack the sides of the sheet into the timbers using galvanised clouts - it looks as though that's what previously be done.
Any help would be gratefully received !
