Hi
We are refurbishing our recently bought mid terraced house in London. We started to remove the wall paper to redecorate the property and a lot of the old plaster started to also come off the wall. In the end we decided to strip the property back to bare walls as well as removed the old lath and plaster ceiling.
I am not sure what type of plaster/render is required for the walls. The internal walls are constructed of bricks with wooden panelling.
I was planning to initially have the walls rendered with sand & cement mix and then finish off with skimming using multi finish. There has previously been damp problem in the property so we will also be adding a waterproof mix to the render.
Is this ok? I have read that old walls are constructed using lime plaster and this should be used to replaster the walls. I am not sure whether these are lime plaster walls and whether it really makes much difference.
thanks in advance.
GNC
thanks in advance.
GNC
