Replcaing felt roof with metal sheet
15 Mar 2004
Whats the best method to replace a felt roof on a garage with a pitched corrugated roof, sloping either to back or side? Most of it seems fairly straightforward but how do you tackle the edges e.g. sealing them against the weather?
Cheers
Jono
It up to you depending what you want it to look like.
To give you some idea on metal sheeting,on the side use external corner cover sheet,
summerhouse.txt
Rather than go to the bother and expense of replacing a felt roof with a corrugated pitched because of leaking problems, why not try a proven alternative?
You can buy a rubber membrane that fits the entire roof, which is guaranteed no to leak!!
Look here
