My house was built in about 1962 and is a town house and very square in shape. We currently have some scaffolding in place as some of the windows are being fitted with Lintels which were not put into the original outer shell as it had wooded window frame which supported the bricks (I assume) the original soft wood windows rotted and were replaced some years ago.
The builder doing the lintels has commented that our house need repointing as the mortar is very soft, he showed me some areas where the mortar has a powdery surface which can easily be rubbed off.
We have has a slightly damp inside wall in one of the areas where this soft mortar is however this may be due to problems with out flat roof or as advised by a surveyor by water being blown into a breather brick which is located on the outside wall near where the inside wall is damp.
I an not sure if this is really a problem and if it is a problem what the best solution is. I would be grateful for advise on the following :-
1) Does this sound serious?
2) Should the whole building be repointed? or can it be patched?
3) Could I seal the whole surface with something like "Thompsons Water Seal"
4) Are there better solutions?
5) If it dees need repointing is the a DIY job?
6) if Repointing is DIYable, any pointers would be appreciated.
7) As mentioned above a surveyor pointed out that water may be blown into the breather brick and he suggested that the breather brick could be blocked as it is not needed. Does this sound correct?
Many Thanks.
Many Thanks.
