Repointing gable end wall
3 Jul 2007
Manchester
As an electrician, repointing isn't my forte!
However, as I have a little spare time I'm wanting to give it a go, can't be that hard can it?
What's the best way to rake out the mortar? It's actually quite soft from around half way up so I may just work on that area for now and leave the harder mortar lower down alone for now.
I have an angle grinder but unfortunately only 3 tier ladders for access so that'll be fun!
When it comes to repointing, I've been advised that a mortar gun would be ideal. I've seen a Roughneck kit for around £17. Would anybody recommend that?
Thanks for any advice at all.
You you ideally need a 4" grinder and a 10mm disc - not one of the thin cutting discs.
The only reasonably good gun is the Pointmaster. I've mentioned it in the tools forum years ago. But even then, you need a specific mix and consistency, and it helps if the bricks are of a certain absorbancy and the joints are of a convenient size. Definitely avoid any gun that resembles a mastic gun with a trigger.
The problem is, pointing requires wet joints, damp bricks and dry-ish mortar. This is not easy using a gun, and can end up like a smudged mess - a bit like when the sparks make good plaster after a re-wire :rolleyes:
Avoid a grinder with a disc, unless you want to sand blast yourself and nick bits out of bricks.
Use an Irwin Mortar Rake, attach a dust extractor and you won't mind doing the repointing.
https://www.amazon.co.uk/Irwin-1050...=1537219218&sr=8-1&keywords=irwin+mortar+rake
Use a mortar gun but follow the instructions, you must use lime or it won't come out. Squirt it in so it also sticks 10mm to 20mm out, it will compress in with the pointing bar.
I'd be wary of using a grinder up a 3 tier ladder anyway....one catch and you're off.
I used a pointing gun a while ago. Just a cheapo one and success all depended on a really wet mix with a good glug of plasticiser. Luckily for me it was on a wall that isn’t visible. In future I’d go for a much dryer mix and a pointing trowel. Would stop the stains on the bricks from the sloppy mix. Might be technique.
Secure the ladder to the wall and at floor level before starting if you don't want to use scaffolding. Then at least the main worry is falling off the ladder rather than also whether the ladder will fall off the wall!
