Hello Good People,
It's been a while to ask a question, but I do read the forums and see lots of help for things which has been very useful.
I've made a pdf of photos to view
http://www.thepenvro.com/Private/Wallfilepdf.pdf
But I can't find an answer to this one. It involves repointing old 8 foot Victorian garden walls. Our terrace is made up of 5 story houses built in 1857. Most are of course broken into flats. We live in the ground floor of ours with the garden and own the basement as well. It's time this job was tackled. The two walls each side seem to be made of of different aggegates. One wall has red and other gray. What are these materials called? I get so many different answers from everyone!
Before I looked at the top of the gray wall, I thought I'd only be repointing the red one with a 3:1 Hybrid using 1 part crushed limestone, 1 part sharp sand, 1 part soft sand & 1 part lime putty. Not purchased yet....found this at
http://www.ecolime.co.uk/?cn=lime-mortar.php
and viewed the video on repointing a stone wall.
I then bought a Pointmaster (vs the trigger gun used in the video.) It looked less fiddly and I will have to be on a ladder over the basement courtyard section.
http://www.pointmaster.co.uk/index.html
I emailed another supplier who promptly told me I cannot use a gun, they do not work at all. They said I need NHL. So am now very confused.com Which to use? The Ecolime mortar product looks easier to use with the Pointmaster to me per the video. It looks like the right product for this old wall.
OK , then I made the mistake of looking at the gray wall on the other side which isn't so bad on the wall surface, but the top of that wall has been splitting apart! I don't often get on the ladder to view the top of that wall, but wanted to clear out the weeds that grow on top and found sapling trees growing out of it in early spring!
Deceased neighbour previously had cut down trees in her garden that shed leaves and made compost that worked into the top between the bricks...no capstones are in place. Sometime along the way she had mortar poured in but that must have been on top of some of the soil as I can lift some if it out and have tried to pull out roots of ivy and whatever. I've cut and killed off the stumps of the two saplings in early spring and they've not regenerated. Only the ivy seems to keep coming back. I think she did one a dozen years ago, maybe about the same time the mortar was filled. I can only dig down so far to get the dirt out. I've re-dosed with masses of root and stump killer and am pulling out all what I think are ivy roots...but will reach a point where I can go any deeper.
How best to fill? With some crumbling bits of stone and mortar for a bed, then fill with mortar? The new owner is a school who bought the flat for their chaplain and this is not going to be a priority for them, so am not going to bother, will just fix the top and my side. Up to them to sort their side.
OK will stop now... any help appreciated. This will obviously take quite a bit of time and plan to do some soon and then leave until next spring. The men in my house have other jobs to go to, so home improvements fall to me.
Lew
Lew
