It's not a fault code.
This symbol denotes the boiler is in "syphon fill mode".
Basically, it will flash this symbol for approx 8 mins when a fresh demand for heating is on.
It denotes that the boiler is in minimum gas rate and in theory means the condensate syphon will be full before the boiler goes into high rate for heating.
Hope this helps
