Hi, have been reading through the excellent information on this site for a while now as having bought my first house (yay!) I am now starting to exhibit symptoms of the DIY fever
My first post, but almost certainly not my last, so go easy on me!
I have a fully pumped indirect heating system, and it would seem the 3-port motorised valve has packed up. Having carefully worked through a series of tests and check I have reached the following conclusion:
The valve is a British Gas one (BGMVSP-23) and it would seem the motor has given up as I get 240V across the live(white)/neutral wires when the CH is on, and 240V across the live(red)/neutral wires when the HW is on, but the valve never switches, it is permanently set to deliver only HW (and thus our CH does not work, although I can force the valve manually).
So my questions are:
* Do people agree with the diagnosis, i.e. the motor is dead/jammed?
* What would be the simplest/cheapest route to sort this out, can I just get a new motor rather than a whole new valve? And if so, would something like this be a suitable replacement?
* Having looked at what is available to purchase, would it be worth taking the opportunity to simply replace the whole valve anyway with something a bit better (the current one seems fairly basic). The ACL Drayton, Danfoss Randall, and Honeywell valves seem like they might be of a higher build quality and might last longer, or is there very little difference?
Many thanks in advance for all advice offered!
Ben.
Ben.
