Reset Accenta 6 House Alarm...
Status
Not open for further replies.
28 Dec 2007
Hello All,
I have recently moved in to a new house that is fitted with an Accenta 6 alarm.
I was advised by the previous owner that the battery for the alarm needs replacing, so I have just purchased a replacement.
What I would like to know, is how do I now reset the alarm once the new battery's fitted?
The current battery isn't attached to the alarm, and the fuse has been pulled out. But every time I attach the battery or plug the fuse back in, the alarm sounds!
Can someone provide step-by-step instructions as to what I should do? The previous owner has provided me with the pin number for the alarm.
Thanks in advance.
Matty
Hello All,
Thanks in advance.
Matty
- Connect the battery
- close the panel
- put the fuse back in the spur
- enter code into keypad.
- press reset
Hello All,
Thanks in advance.
Matty
- close the panel
- press reset
I thought it was 'mains first'.
Hello All,
Thanks in advance.
Matty
- close the panel
- press reset
not if it was decommisioned in the correct order by the ex owner, mains first when its crashed
So it's battery first then? I could have sworn you've changed your tune.
But Saxondale said the other month:
"assuming you have 240v to the fused spur it just needs a new control panel battery
power it all down (outside sounder should be ringing)
mains on
connect new battery
replace lid
enter code"
So what gives huh? I guess Saxondale isn't man enough to admit he was wrong.
He wasn't and isn't wrong.
You are. You don't appear to know anything thing about a crashed panel and a simple dead battery.
And please don't tell us what it says in the manual. I can assure you we don't put everything in the manuals.
Security Supplies is a shopkeeper. Now let's take this to the TECHNICAL level. Saxondale can't as he admits he has no knowledge of electronics.
Do you know the two people you refer to???
I'll take that as a NO then.
I on the other hand do know them AND can vouch for their credentials.
Status
