Hi all,
Hoping for some help with planning my new self build home CCTV system.
I am currently doing the first fix and I need to decide on the type of cable I should be fitting.
I already have loads of shotgun coax and cat5E cable so ideally would like to use one of these however if using cat6 or other has cost effective benefits then I would rather do that.
I wish to use either IP cameras or HDCVI cameras which I believe are a cheaper alternative.
In total I am probably going to be installing 6 to 8 cameras.
Any help much appreciated.
Thanks.
Mark.
Thanks.
Mark.
