Hi, just about to purchase some thermostat controlled plugs. The heaters i will use will be 3000w as a temporary thing while proper heating is installed. However i will use these thermostatic controlled plugs else where when they are finished powering the 3000w heaters. (will be used on low power tube heaters)
The specs say they can handle -
· Maximum resistive load: 13A 3000W
· Maximum inductive load: 2A 460W
Whats the difference ?
thanks
thanks
