Hello, yes, it is a quote question...but...with measurements! Not just a random stab in the dark one.
So, I am looking at getting:
1 x french door. Opening size: W225cm H228cm -Full Door Opening: 150cm With top openers on the partial length sidelights. I will probably retain some cill on the lower half of the sidelights. This does require some brick removal and lintel.
1x Kitchen Window: W103cm, H113cm with a top opener and larger bottom opener.
1 x Bedroom Window: W223cm H133cm, in a traditional 4 pane split. With two bottom openers and two top.
1x Bathroom window: W101, H115cm. With a top opener (maybe a bottom opener too).
1x toilet window: W39cm, H84cm with a small bottom opener.
1 x landing window: W55cm, H148cm, with large bottom opener (H101cm, W46cm)
Windows would be a Eurocell profile. Lock on the French door would be a ABS Avocet style lock. It would be standard double glazing with warm spacer bars etc.
What ball park would be be talking?
Anything I should consider?
Are there usually any options for slightly tinted windows? Should I consider laminated glass for the french door?
