Restoring a knotty pine table top
4 May 2010
Nottinghamshire
I'm having a bit of a disaster. We have an old 70's knotty pine dining table that has quite a bit of sentimental value. The varnish was old and chipped, so I sanded it down and applied some Ronseal brush wax. The wax has caused some of the fibres to expand making the finish quite rough in places. The wax is also a bit too orangey to tone in with the side board.
So my questions are:
What should I have done / can I do to improve the finish?
Is there any way I can alter the colour of the table to tone in with the sideboard?
I've been at this for 2 days now and I'm at the end of my tether. I would appreciate any advice that anyone has to offer.
Regards Pete
is it a flat pine table with a square edge and no moulding
if it is you can unscrew the top flip it over and start again
and what you descibe is called "raising the grain"that happens when you use water based products or just plane old water
you should have wiped down with a damp cloth then re-sanded when dry
brushing wax is usless in my opinion but do not fret as you can just use wax remover which will work quite effectivly because the wax is so recent.
If the wax had a stain in it though it will not come out as its removes so you will need to re-sand it . sorry :cry:
