Restoring Exterior Windows Concrete Mouldings
14 Jun 2004
The concret moulding around my exterior window frame are crumbling.
Could I have your opinions on the best way to restore them - should this be done by a professional? Looks like it would involve me shaping the ciment to reform the original shape and not sure if I'm capable.
Cheers
Ian
I think you'd best get it checked by a structural engineer first to see if it's superficial or more serious - otherwise you'll repair one part only to find it going elsewhere.
As far as repair is concerned I used to use an epoxy resin based mortar as this bonded well and was easy to work with however that was many years ago and I don't know what's currently on the market. It depends on the scale of the problem.
Thanks for this.
The damage is purely cosmetic - the concrete isn't supporting any structure but is for decoration.
I would need to get a paste I could mould with but something not too smooth as the mouldings that aren't damaged have a slight ripple effect on their surface.
