restoring original floorboards
24 Oct 2005
Yorkshire
i am sanding and restoring original floorboards but an old fireplace has been taken out and new boards put in where the hearth was.they are out of line not as wide and look a mess how can i correct this bearing in mind i am going to stain it all the same colour after i don't want this area to spoil the look also there is one right in the middle of the floor which caNT BE COVERED OVER with furniture etc. thanks in anticipation for your replies
What about taking up the old floorboards in out of sight area or under the sofa and use that etc.
masonas idea is a good un ;) but watch out for leg or castor marks
other areas under the stairs in a cupboard smallest room in the house
a length or two from near the edge off the room concerned and replace the whole length with new cut to size
obviously if its tounge and groove flooring non of the abouve will be easy
as youve either got to cut the tounge and prize up gently bringing the next and the next board all up at the same time so as not to break the txg
or punch the nails through and slide the planks out
reclemation yards!!!
