A garage has a restrictive planning condition imposed on it which says it should be kept available at all times for garage use.
In the proposed plan it was indicated that there is no access from the garage to the other parties of the house. However this garage has not been developed according to the proposed plan and there is an access from the garage to the others parts of the house. Moreover it has been developed in such a way that to go to the upper floors it is necessary to go first through the garage
1.
Even though this was internal work I would like to know if planning permission should have been necessary to develop the garage in a different way that this indicated in the proposed plan because the fact that there is an access from the garage to the other parts of the house means that it is less likely that this garage is kept at all times for garage use because it will be easier for the occupier of this house to use the garage as an additional room.
2.
I would like to know if the owner of this property applies for a lawful development certificate if he has to inform the planning department that his garage has been development in this way because this could be material information because of this previous restrictive condition imposed on the garage
1.
2.
