All,
Just after a bit of advice on building a retaining wall in my garden. I back onto a field and have a ditch between my garden and the field. When it rains this ditch fills with water and runs round the back of the estate. Currently we have a concrete pillar and gravel board retaining wall which over the last 5 years has moved backwards and causing the soil to drop.
I have done a little research including getting quotes for someone else to do the work. But £3k is a bit steep for me. I have done brickwork in the past but nothing like this. Mainly filling in gaps and doors and such.
The plan is to remove the old wall and build a new one out of concrete block. The length of this wall is 10 meters and just under 1 meter high. Currently the concrete boards are separated with a gap of about 1/2 inch to allow water to drain. Also at the base of the wall is gravel allowing for drainage. Also at each end of the wall I need to come back about a meter to join the existing wall. I have extended the garden a bit. So a bit like a U shape.
I plan to dig a foundation 30cm below the ditch level and lay a foundation 15cm thick and 40cm wide. With pillars at each end for added strength. I only plan to use 1 row of hollow 9" concrete block and fill in with concrete as well. I will put seep holes in for drainage to allow for the water. Behind the wall I plan to use the gravel for extra draining. Does this seem right? if so how often? Do I need plastic piping for additional drainage? also do I require a membrane between the gravel and soil? ? Will I require additional pillars along the wall?
The top of the wall will just be level off or maybe some very low capping stone's I thought about trying to but my wooden post's for the fence into the concrete hollows. Will just be a simple fence with post's and a few horizontal lengths of wood to stop the kids falling over. Don't want to ruin the view.
Any advice is greatly appreciated. I have also been looking for book's but not seen one yet.
