retaining patio wall
20 Nov 2011
Lancashire
Hi All.
I am wanting to build a retaining wall for a patio to sit on, the wall will be 10mt long x 1.5 mt high as their is a slope 1 in 3 so the 1.5 mt will fetch the height of the wall to ground level, I am intending to use hollow concrete block, but the thing I am not sure of is should I use concrete strip footings or will a hardcore footing be ok.
Cheers Karl. :D
Structural Engineer innit, don't be scared though find the right one it'd be about £200 max to design a proper wall using the methods you are comfortable with.
There's no such thing as a hardcore footing BTW.
OH sorry, foundation then, why would I need a SE for a 1.5 mt high wall in the garden its not the empire sate building am after constructing or any big excavations just using a shovel to make a trench. all I am needing is some advice for a suitable foundation for the type of wall structure i.e. concrete hollow block relevant to height and use. :D
Cos if you get it wrong (and DIYers sometimes do) it will kill someone if it goes over.
Yea some hardcore for the foundation will do it. :LOL:
I can assure you I am more than capable to do the job , I was just unsure about the foundations ( I know this is the most important part of the job ) whats the job with foundation blocks , these are something new to me , can these be used instead of a concrete stip , I am thinking for ease of use thats all. :D
OK, sorted now , concrete strip footings , concrete block foundation / wall . thanks for the reply's . :)
