I am thinking of sinking our trampoline in the grass as we are fed up with staring at its cage like enclosure. (10 m diameter X 70 cm height)
I will need to dig the circle and build a retaining wall plus dig a channel for drainage pipe. Anyone has done this before, advise appreciated.
A) Can I use block instead of brick and which type given that its all underground level?
B) Do I need to damp proof behind the retaining circle wall and why?
C) I don't intend to put a membrane sheet inside the circle base either but just hard core sloping towards the drainage pipe, is that reasonable so that the water will dispense and soak away into the ground too.
D) How deep and wide a foundation do I need for the circle wall?
E) Anything else I should worry about?
