Hello,
I was looking for some advice on building a retaining wall in my garden and would appreciate any comments or help you can give.
I am going to be building the wall with 7n concrete blocks and was wondering if i should lay the first course blocks on their side and then two normal courses on top which would give a 15mm gap or if i could just lay two courses and have a 50mm gap to enable me to use my bricky tool. I would then fill the gap with concrete. as attached
The height of soil to hold back is 750mm so i was going to have a 200mm deep and 500mm wide foundation with the top of the foundation 150mm below the lower ground level. This would then give a total retained height of 900mm. Would it be a good idea to build a deeper flange into the foundation to help prevent slippage or would this be a waste of time?
thanks very much
Trevor
thanks very much
Trevor
