My system uses an Ideal FF270 with TRVs on all but 3 small rads (2 in the hall and 1 in the loo) and seems to have 2 separate 2-port valves for CH and HW. The installer fitted a gate valve bypass in the airing cupboard which he set to about 4 turns open.
Now the system works OK i.e. there is no noise and the radiators get warm eventually. However, I wondered if there was any advantage to retrofitting an automatic bypass. When operating, the boiler does seem to cycle quite a lot even when the rads are cold and it takse quite a while to get all the rads hot everywhere (I think they are balanced correctly though). I have read that an automatic bypass will get the rads hot quicker and more efficiently, possibly saving money in the long run
But is it worth it ?
