Hey there,
I'm in the process of buying a house that has had an internal load-bearing wall knocked through by the current owners. It was done by a builder but building control was not consulted. I would like to get it regularised when I move in but I'm trying to work out if it is a major job.
The wall was/is between a kitchen-diner and supports the floor joists on the first floor. An RSJ has been installed that spans about 2.5m of the removed wall. The RSJ is cased in plasterboard and I have not removed it to see what load-bearing there is on the brickwork either side of the RSJ. One end of the RSJ appears to rests on a portion of the remaining interior wall and the other seems to rest on the internal (breezeblock) skin. It is plastered over, so I cannot see if a load-spreader is installed between the RSJ and the internal brick skin.
The weight of the roof appears supported by the external skin so I think the only weight this internal RSJ supports is the weight in 2 of the bedrooms upstairs.
My questions are:
1/ How easy is this to get retrospective approval for?
2/ Does it sound like the above would meet building regs IF load-spreaders are found to be present? I.e. would this also need its own pillar or is the internal skin sufficient?
3/ If it does not meet building control, what remedial work might be needed and what might it cost?
Thanks for your advice.
My questions are:
