Good Morning - Why is you not at work ?
I was checking out the plumbing at home the other, it's a sealed system Combi. Was trying to understand the logic of the feed and return pipes to and from the rads. I followed the hot water feed from the combi and each one went to the right side of the Rad where either a TRV is situated or a heate control valve. Anyway I thought yes hot water in and not so hot coming out of the return valve end. Well I understood this untill one of the radiators was piped up the opisite way round. Feedpipe was connected to the return valve end / return pipe to control end. Derrrrrrrrrrrrrr
Is this right - what's the reason behind it ?
Always appreciate everyone's help
