Hello.
I have a small (12m2) area of floor to heat and rather than installing a pump/manifold was looking at using a Return Water Temperature Limit valve.
However im not sure if this is a good idea as I cant regulate the flow temp as the pipe enters the floor. I understand it should be somewhere around 45 degrees but it would be nearer 80 as it entered the floor if I just use a Return Water Temperature Limit valve and thus damage the flooring / slab?
Should also use a TMV on the flow or will this confuse everything.
