Hiya is it wise to reuse central heating copper pipe for warm tap supply (no drinking involved, I mean no drinking water) does the black stuff get cleared out quick or does it remain polluting the supply slowly for years? I could save loadsa money if it worked .
How do you intend to clean out all of the black stuff? You may think that you have cleared it all, but a lot will still be left behind, and is sure to loosen and either come out of the taps or block things up at a later date.
If you REALLY need to save money, why not use plastic Speedfit pipe?
