I am about to relay old floorboards after carrying out work to a bedroom after which I will move onto the next room. I had thought about replacing the old and probably original floorboards with sheet timber as I go as I thought the boards had been butchered over the years as the house had been modernised. As it turns out the butchery has been limited to hallways from what I can see so I am hoping to retain the original in 90% of the house saving money and probably leaving a better product.
The boards are in good condition but have been sanded down by the previous owners. Should I run the boards through a planner/thicknesses to rip 1mm from the sanded side to give a perfect finish or just relay as is? Or lay sanded side down?
How many mm should be left between 1) board and board 2) board and wall to allow for movement. I plan to screw down rather than nail to prevent potential seeking.
