Reusing UPVC glass on a lean to roof?
23 Jun 2024
I am having an old UPVC conservatory pulled down. Elsewhere I have an open sided lean to shelter attached to the house which currently is roofed with thin polycarbonate sheets that are failing and need to be replaced. The timber supports for the lean to roof are very strong and sound. Could the UPVC double glazing units be used to create a clear glass roof as single sheet glass? as a double glazed unit? or not at all? If this is possible how can I make it work well & be safe?
It probably won't be safe, and they probably won't be the right size, so will look odd without redoing the framework it sits on.
Can you confirm that the glass is toughened or laminated?
If not, and if you must, then get some adhesive window film. Clear or frosted/patterned, and cover the inside of the glass with it. Just in case an errant tile falls off the roof and onto your glass.
