I've got a y plan system which was working fine until the pump failed. I drained the system which was sludgy and replaced the pump. The radiators are now heating up on a hot water demand even after replacing the 3 port to try and cure it.
Considering reverse circulation wasn't a problem until the pump failed can a partial blockage
cause this issue. The f&e pipes tee in before the pump ok and there's no pipes after the cylinder return.
Ani ideas?
Ani ideas?
