Hi, I bought an old lamp and am rewiring it.
At the bulb-socket, there is only space for two wires. On the original wiring, someone had cut the ground wire. This then runs through to the base of the lamp. At the base, the wire cover is cut and slipped open. Here the two brown wires are cut and inserted into what looks like a fuse; the two greens are grounded on a small screw, and the blues run between the two ends of the wire covering. The other end of the whole three-core wire is then wired to the three-pong plug as usual. Can anyone tell me if this method is safe? Sorry if I haven't explained it well, I am new to this. Is the alternative to buy a new socket which has space for all three wires?
Thanks for your help,
LUX
LUX
