Hello everyone.
Hoping someone can steer me in the right direction.
I have a Vokera Mynute 20-70se conventional boiler which is 15 years old.
For the past year I have had problems with interference on my TV/radio everytime the boiler is on and I have confirmed that it is co-incidental with the thermostat clicking off.
In February I had the thermostat replaced and this appeared to solve the problem for about 3 months, at which point it started happening again. Exact same symptoms.
The repairman is reluctant to replace the thermostat again and says what the system needs is a suppressor wired across the mains supply but that I will need to employ an electrician to do it. (Apparently there was a suppression kit produced by Vokera but it is now obsolete).
If this interference is being caused by the thermostat then would the suppression not need to be applied across the thermostat rather than the mains?
Part of me thinks I should just get a new boiler, given its age, but I doubt the new one would be able to be installed in the same location, what with new regulations and the need for drainage, etc, and I don't relish my house being torn apart to relocate it.
Thanks in advance.
Thanks in advance.
